• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Spot Slope for Ramps
    479 Views, 10 Replies
    11-23-2012 08:27 AM
    Is there a reason 'Spot Slope' works for floor slabs, but not ramps (in section)?
    Is there a work-around to have slopes notated for ramps?
    Thank you in advance
    Please use plain text.
    Alfredo_Medina
    Re: Spot Slope for Ramps
    11-23-2012 10:24 AM in reply to: nikana2000
    See this other thread:
    http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Spot-Level-Problem/m-p/3571680#M62005
    Planta1 Revit Online Consulting | info@planta1.com
    Active Contributor
    11-23-2012 12:52 PM in reply to: Alfredo_Medina
    Thank you for the response Alfredo, however I'm looking for a spot "slope", not "elevation" or level.
    I've attached a photo showing the difference.
    /using 2013
    Alfredo_Medina
    11-23-2012 01:35 PM in reply to: nikana2000
    Spot slope works for ramps in section. (At least here, Revit 2013). The issue happens in the floor plan view, and the same trick "works" in that case, too.
    Active Contributor
    11-26-2012 12:43 PM in reply to: Alfredo_Medina
    I tried again Alfredo in a separate/new file, and am unable to have 'spot slope' for ramps in section.
    I even drew the ramp exactly perpendicular to the section line.
    Active Contributor
    sagar.londonites
    11-30-2012 08:56 PM in reply to: nikana2000
    Go to a 3D view, align it to Top mode so that you can see the ramp just like in a Plan view.
    You'll now be able to add a spot slope to the ramp. Copy the spot slope, go to the Plan view, 'Paste to Current View'. Done!
    - Sagar
    Active Contributor
    12-05-2012 01:39 PM in reply to: sagar.londonites
    Thank you Sagar, but that does not work for me either.  (see attached screencapture for error message)
    Also, I require the 'spot slope' for a section, not plan.
    Alfredo_Medina
    12-05-2012 01:44 PM in reply to: nikana2000
    Spot slope on ramps works fine for me in elevation or section view (Revit 2013). In plan, it still has that "bug" which can be "fixed" by placing the spot slope first on a floor and then moving the spot slope to the ramp.
    Active Contributor
    12-05-2012 04:09 PM in reply to: Alfredo_Medina
    Digging into the issue deeper, I can get a spot slope in section only if the ramp has a railing (which the slope is not related to the ramp).
    I thought I'd try this from a new project created from a standard 'Architectural' template, but received the same results as above.  It is attached.
    Are you able to place a a spot slope in section to the ramp without rails?
    /Edit: Not letting me attach the 880kb RVT file
    Alfredo_Medina
    12-05-2012 04:19 PM in reply to: nikana2000
    Yes, without rails, or with rails.
