• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Accepted Solution
    Split face on curved walls
    327 Views, 3 Replies
    11-03-2012 04:21 AM
    I am using Split Face to colour rooms in my floor plan. This works perfectly for all the rooms with straight walls. When I try to Split Face on a room facing the exterior of the building (where the floor slab is slightly curved), I get the error message, "Ends of an open loop in sketch splitting face do not lie on an edge of the face to split". Is there a 'work around' this? (No amount of 'zoomming in' to try and get the picked face directly in the correct spot seems to work.
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: Split face on curved walls
    11-03-2012 05:30 AM in reply to: anitacooksey
    Split face and Edit Profile work on planar surfaces, only, not on curved surfaces. The alternative, even for flat surfaces, is to model the finish layers as separate wall elements, thin walls with the true thickness and materials. The same applies to floors.
    Planta1 Revit Online Consulting | info@planta1.com
    Member
    11-03-2012 04:44 PM in reply to: Alfredo_Medina
    Thanks so much. That's very helpful.
    11-05-2012 04:44 AM in reply to: anitacooksey
    Just remember, that if you have penetrations in these "layered" WALLS, such as Doors or Windows,, you'll need to use ht Join command in order for the opening to go thru all of the components.
    Mike
    Michael L. Maloney
    Virtual World Designs
    VDC & BIM Model Design, Clash & Coordination
    mike@VirtualWorldDesigns.com
    Building Design Suite Ultimate 2013
    Charlotte/Gastonia, NC & Jacksonville, Fl.
