• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Sorting in Revit Schedules
    468 Views, 10 Replies
    12-09-2011 09:16 AM
    I am wanting to sort by more than 4 parameters in a single schedule.  Revit 2012 only has 4 options.  Can more be added?
    Please use plain text.
    Alfredo_Medina
    Re: Sorting in Revit Schedules
    12-09-2011 09:57 AM in reply to: jverdugt
    No. Any more info on what you are trying to do?
    Planta1 Revit Online Consulting | info@planta1.com
    Product Support
    alan.quinn
    12-12-2011 10:29 AM in reply to: jverdugt
    Just following up on Alfredo’s post. Without more information it’s impossible to make recommendations and/or suggestions.
    Alan Quinn
    Support Specialist
    Product Support
    Member
    12-13-2011 01:41 PM in reply to: jverdugt
    Thanks for the reply.  We were able to figure out a way to work around this to the accuracy we needed.
    Member
    11-12-2012 08:02 AM in reply to: jverdugt
    Hi, how did you solve this? We have the same problem.
    We have a schedule listing window information, e.g. Window Type F01.
    We sort our Schedule by:
    Type Mark, then by:
    SwingDirection, then by:
    FireClass, then by:
    SoundClass.
    And we need to add by:
    SecurityClass
    But Revit has by default only 4 levels or sorting.
    Any ideas how we can go about adding more sorting parameters?
    Lena
    11-12-2012 08:53 AM in reply to: lena.v
    I have accomplished this in the past by creating a Calculated Value that combined two of the fields for the purposes of establishing a sort order for our Light Fixture Schedule. I already had the top two "Sort Slots" used, so I had to combine LampWattage and LampQuantity (to be sorted in respective order) into a single sort. This is a rough summary of my scenario:
    Name                  Type                       Units
    LampWattage     Parameter               Watts
    LampQuantity     Parameter               Integer
    LampSort            Calculated Value    Number
    The formula for LampSort is: =(LampWattage / 1 W) + (LampQuantity / 100)
    The above formula will combine the two to produce a number such as 32.03 (32W, 3-Lamp) or 54.01 (54W,1-Lamp), which allows for proper sorting.
    As for your specific situation, I would assume that your Parameters "SwingDirection", "FireClass", and "SoundClass" are all Text Parameters, correct?
    It may still be possible to combine them using this method, but could you elaborate on your parameters a little bit, specifically, are there a large number of possible values for these parameters? I'm thinking there are aren't many possibilities for "SwingDirection", but what about the other two?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Member
    11-12-2012 09:08 AM in reply to: CADastrophe
    Great, that sounds like an idea!
    You're right though, my parameters are texts.
    Is it possible to combine two text strings to one?
    11-12-2012 09:34 AM in reply to: lena.v
    Unfortunately, Revit is incapable of the simple task of combining text strings, which is responsible for the forehead-shaped damage to my desk. banghead.gif
    Spoiler
    My questions earlier about the number of possible values is important to this method - the more values, the more complicated it becomes. Example:
    I want to combine BoxSize and BoxColor, which are both Text parameters. I would first have to create a Calculated Value for each of these that will convert the value to an Integer. Here is the formula for the respective Calculated Values:
    BoxSizeSort = if(BoxSize = "Small", 1,if(BoxSize = "Medium", 2, 3))
    BoxColorSort = if(BoxColor = "Blue", 1, if(BoxColor = "Green", 2, if(BoxColor = "Orange", 3, if(BoxColor = "Red", 4, 5)))
    **The above formulas must include ALL possibilities, so if there are limitless options, then this is not possible.
    Finally, a third Calculated Value is needed to combine the other two: BoxSort = BoxSizeSort + (BoxColorSort / 10)
    Edit: Nevermind the above in the spoiler - I had forgotten that Revit does not allow a String to be used in a conditional statement... More banghead.gif
    Member
    11-12-2012 09:46 AM in reply to: CADastrophe
    Ok, thank you for helping out!
    Maybe the conversion to text may be too elaborate for this project.
    How ever, the calculated value idea makes me think we will have to combine two parameters into one to simplify matters. Hope Autodesk will give us more control in future versions though.
    Thank you for quick replies!
    /Lena
    11-12-2012 09:55 AM in reply to: lena.v
    Unfortunately, with all of the parameters being Text, I believe that you will have to combine them outside the schedule. I'll post if think of any other possibilities...
