• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    atleaas
    Accepted Solution
    Slanted column meets "Beam/Column joints"
    215 Views, 4 Replies
    02-07-2012 02:34 AM
    Hello
    I have a problem inserting the slanted columns when I use the "Beam/Column joints" commando. When I insert the slanted column, the beams are divided.
    It should look like picture 1, but it always ends up as image 2. How can I solve this?
    Distinguished Mentor
    Re: Slanted column meets "Beam/Column joints"
    02-07-2012 06:26 AM in reply to: atleaas
    Two suggestions:
    1. Use the Coping Tool at the joint.
    2. Try using a Brace (beam/framing member) instead of a slanted column.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    *Pro
    Alfredo_Medina
    02-07-2012 06:47 AM in reply to: ccollins
    Usually, there are plates at those locations, to weld the pieces together. Those plates are not automatically generated by the program. The user has to create the families and place them.
    Planta1 Revit Online Consulting | info@planta1.com
    Active Member
    atleaas
    02-08-2012 08:30 AM in reply to: ccollins
    Thank you very much! That did the trick for me.
    The cope tool didn't help me when I used Slanted columns, but it worked with Brace.
    Went to Elevation view, and used the Brace tool. Then I streched the columns through the beam and used the cope tool. Did this in all directions.
    Alfredo Medina: Yes, I know. I'm placing the plates after the columns. Maybe this is a bit inconvenient way to do it, but I'm not sure how else I can do it. At least it looks like the columns slide into the plates by doing it this way, even though it's a bit time consuming.
    02-09-2012 06:20 AM in reply to: atleaas
    Glad you got it working!
    cheers:smileyhappy:
    Cliff B. Collins
    St. Louis, MO
