Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Setting Temp Dimension Size
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
Revit 2010
I'm trying to change the temp dimension size. (Is there anyone who can read the 8pt.?) I've looked at the .ini file and don't see where I can change it. I've also read where it can be changed via some 'option'. Under which tab and panel is the 'option'?
Hey, I'm new at this...
Central Standard
Re: Setting Temp Dimension Size
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't have 2010 installed to show exactly where it is, but it is goign to be close to what I am showing. The "Options" dialog is opened from the Application menu. The application menu is the big purple "R" in the upper left corner of the application window. In the options dialog you will find a tab that says "Graphics" on this tab is the control for temp dim appearance.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Jeff, but it apeears the 2010 version is slighly different. It has a slightly different set up which does not show a size selection for the temp dims. See the attached file.
I'll keep looking.
Greg
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is a newer feature - I don't believe it was aviable in 2010.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: lisa@kalblue.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is a snippet from my 2010 revit.ini file. If I remember correctly it defaults to 8 points if no entry is there, so you need to add in the line TempDim....
[Graphics]
InvertBackground=0
TempDimFontSizeInPoints=14
[Colors]
HiliteColor=16741179
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That's it!
What I didn't understand from some previous posts (not in this thread) that the line "TempDim....." had to be completly added. I was looking for that line to edit and of course it's not there.
Thank to all who replied!
