Autodesk Revit Architecture
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Set Roof Edge-Face Square to Slope
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
426 Views, 6 Replies
05-31-2006 10:49 PM
Hi, I have a generic 5" thick rectangular concrete roof layout with a single directional slope of 1:3.
Is there a way to have the bottom and upper egde-faces be square (Two Cut - Square) to the slope and not vertical (Two Cut - Plumb) ?
No facia applied to this roofing system. Just plane jane.
*Jay
Re: Set Roof Edge-Face Square to Slope
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-01-2006 08:11 AM in reply to:
Wotdat
I just went through this ordeal. You can have the bottom edge square by
using the two-cut square option in properties with the cut thickness equal
to the thickness of the roof assembly. There is no way to have the top edge
square. The workaround I used was to create an in-place roof family within
which I created a solid extrusion drawn in the side elevation.
wrote in message news:5191768@discussion.autodesk.com...
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-04-2006 03:12 PM in reply to:
Wotdat
Ain't that Silly? You call something " 2-cut square " and only one face is squaring up?
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-04-2006 09:57 PM in reply to:
Wotdat
I don't think I understand the question... Are you asking for the entire eave edge to be square to the top of the roof?
Just use the two cut square option and make the value equal or larger than the roof thickness. When you use a smaller value you get a square portion equal to the value and the bottom returns under the roof.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-04-2006 10:45 PM in reply to:
Wotdat
The thing is, REVIT only recognizes the line with " Defines slope " Properties as face and only that face reacts to the " 2-Cut Square " setting and I think that is what you are referring. What I need to happen is to have the top and bottom edge faces be perpendicular to slope of roof.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-14-2011 01:05 PM in reply to:
Wotdat
Has there been any further development on this topic over the past 4-5 years?
My condition is a square planar roof that has been "rotated" on two axis (using a slope arrow) putting the 4 corners at 4 different z-planes. As stated above only 1 edge can be set to 'two cut square'. I need all 4 edges set to 'two cut square' so I can create a nice extruded fascia around the perimeter with clean miters.
Thanks!
Greg
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-01-2013 12:47 PM in reply to:
Wotdat
I have the same issue. I would like a single slope roof with all edges perpendicular to the roof. I can make that happen for the bottom and sides but not the top. It's 2013, and this program costs thousands so, Autodesk, pull your thumb out and give us a solution already. I'm sick of this.
