Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Self created family willl not load into project file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I created a family and tried loading it into a project I am working on, but it will not show up. Occassionally, the system says it is automatically making it visible, but I am not able to place it in the project. I am capable of loading a family already provided by the Revit program (2013) just not a family I create myself. I have used the tutorial as an example, ensuring it was a solid but that did not help. I also checked/ turned on all of the properties settings but it did not help.
Any suggestions, Thanks in advance.
Family will not load or be visible in project file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I created a family using the tutorial as an example and made sure it was a solid. After I saved it, I tried to load it into my project but it is not visible. I opened the properties box to make sure that everything was checked but it did not help. Occasionally, the system indicates it is overriding something and it shows up, but it will not load. I can load a predetermined family that came with the program, just not a self created family. Can anyone offer a suggestion. I am using Revit 2013. Thanks
Re: Self created family willl load into project file
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It should read; Self created family will NOT load into project
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What type of family did you create?
When you look in the Browser, is it listed?
Please select "Accept as Solution" if your question was answered.
curtainwallBIM.blogspot.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Jon
I created a Generic Model Family using the tutorial ensuring that it was a solid geometry object. It says it is loaded, it is just not visible.
Yes, I can see it in the brower. I saved the file in a folder other than the family library.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If it's in the Browser, expand the category until you see the family and then drag it into a view. If it's Revit 2012 or earlier, post the file and I'll take a look at it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Jon,
Thanks that did work.
