Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Selecting walls by height or thickness.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Selecting walls by height or thickness.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yeah you can hide a wall you're not working on. Just select the wall
and go down to those little glasses on the view bar.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you select a group of elements, you could use the Filter to select only Walls, but not a specific Type of Wall. You could create one or more View Filters to easily control the visibility of Walls based on their thickness, using the Width parameter. Go to:
Visibility/Graphics Overrides » Filters tab » "Edit/New..." button towards the bottom.
Create a new filter, check the Walls category from the list, and set the filter rules as appropriate. (Just ask if you need any assistance).
WIth this, you can turn off the walls that fit within the Filter Rules, so you can select only the Walls that you want to select. This does not appear to be possible to do according to Wall Height, though.
⁞|⁞ Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
where is this option found? i'm using 2012 version
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hit "VG" for Visibility/Graphics Overrides and see attached image.
⁞|⁞ Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
you should also try to create a wall schedule and try to filter the desired walls using filters there.
let us know the results plz.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
thank you for providing this tip. this works great ![]()
