• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    GPR_MN
    Saving .rvt files to Lion Server
    330 Views, 3 Replies
    10-23-2012 08:32 AM
    We are running Revit 2012 Suites on iMac w/Parallels w/Windows XP SP3.  Office file server is a Lion Server running 10.7.5.  While working in Revit we can; save PDF's to server, export DWG/DXF to server, and for a few moments after opening a file we can save a .rvt file to the server. But after more than ~2min, Revit freezes at any save attempt and we have to force quit through the task manager.
    Last few lines of journal entry for event reads as follows.
    [ Jrn.Directive "DocSymbol"  _
             , "[Res.TemplateLionTest.rvt]"
     '  0.000008    2:<<<BackupFileManager::smileytongue:reUnlockPreCommit
     '  0.003275     3:<<<relinquishAllLocks
     '  0.003386    2:<<m_oSaveToTempFile->preCommit
     ' 2:< Error encountered renaming main file to backup. Error message: Access to P:\Projects\XXXXX Project\CAD\Revit\Res.TemplateLionTest.rvt was denied.   ]
    then repeats the '2:< Error... line for a few pages..
    this error has persisted throught Revit 2011 and 2012 versions.
    Anyone else encounter this? Possibly with solution?
    Please use plain text.
    Active Contributor
    GPR_MN
    Re: Saving .rvt files to Lion Server
    10-26-2012 10:26 AM in reply to: GPR_MN
    So, is the lack of response from anyone in Autodesk due to Revit not being supported in a Mac environment? Apparently I'm not the only one with issues in saving .rvt files to a Lion Server.
    Product Support
    alan.quinn
    10-29-2012 09:44 AM in reply to: GPR_MN
    Correct, this environment is a not supported.
    Thanks for posting.
    Alan Quinn
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    GPR_MN
    10-29-2012 10:55 AM in reply to: GPR_MN
    ah, a non-solution solution. thats great. i should just pile on the kudos eh?
    maybe you could have left it 'unsolved' on the chance that one of us subscribers may have figured something out.
