• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Saving in revit ( big problem)
    174 Views, 3 Replies
    09-18-2012 01:23 PM
    hey guys, i currently use the revit architecture 2011 version, i had a prior installation of 2011 on my laptop however for some reason it could no longer detect y license so i uninstalled it, then downloaded the same version again, this time a different serial number was distrubuted. The program works fine, however whenever i attempt to open the file at my schools computer in thei 2011 version, i try to save, it states "file not saved" so i then save it under another name and it states that that "the file ect was saved in a later version of revit and cannot be retrieved in this version" how is this possible when the version i initially used is from revit 2011???
    Please use plain text.
    DarrenP
    Re: Saving in revit ( big problem)
    09-18-2012 01:37 PM in reply to: plangle1
    are you sure its the same version as yours?
    Member
    09-18-2012 02:08 PM in reply to: plangle1
    yes i'm sure
    Member
    09-18-2012 03:07 PM in reply to: plangle1
    ah, i figured out the issue, it was a problem with my flash drive , it's corrected now
