• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Save Button is greyed out
    158 Views, 3 Replies
    01-10-2013 02:07 PM
    Hi! I am very new to Revit & am on the learning cuve now with the "Ascent Training Manuals". I find that my save button is greyed out both on the ribbon and in the left dropdown window above "save as"! Any ideas why this is happening. The project does seem to be automatically saving. Just can't access that button! Using Revit 2013 Ultimate. Win 7 64 Pro.
    Any ideas!
    Thanks!
    Paul Rymal
    Please use plain text.
    *Expert Elite*
    Re: Save Button is greyed out
    01-10-2013 02:28 PM in reply to: PAULRYMAL7709
    Are you using Revit in Trial Mode or Viewer Mode? ( I think this is set when you install the program?).
    Is your project a Central File / Workset enabled? ( Centyral on file server, local copy on workstation.)
    Sometimes the save button will be greyed out if you are working in the central file and trying to save locally....
    as I recall.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Re: Save Button is greyed out (Solved)!
    01-12-2013 04:35 PM in reply to: ccollins
    Thanks I figured it out! Paul Rymal
    01-15-2013 06:07 PM in reply to: ccollins
    Hi! Not sure what you mean by "Trial" mode & "Viewer Mode" I have installed on a workstation "desktop". No Server involved. I am fully licensed & registered with my software. Don't recall having this problem before. I am using a files from "Autodesk Revit Architecture 2012" which I download from the internet through this book I have purchased. On my other projects there is no problem saving! Just this one. RYMAL DRAFTING INC. EDMONTON, ALBERTA (780)634-5303
