• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    toxicarea
    Same material looks different when rendered Revit 2011
    669 Views, 1 Replies
    01-01-2011 07:36 PM
    I put two pics of the problem. Notice the different look of the balusters. It is the same material on two different renderings (same project). Both renders are at best quality. I don not belive that it is the light that makes the change. The difference is more than obvious to me. How can i fix it?
    Additionally, look at the glass reflection...it looks different too.
    Please use plain text.
    Employee
    Re: Same material looks different when rendered Revit 2011
    01-04-2011 11:27 AM in reply to: toxicarea
    Can you verify if you create a new view looking at the same area, does the material appear correct here or black as well?  I want to isolate if that specific view may have some corruption.
    Also are all of the settings the same between the views [Discipline, Phase, etc.].  What if you temporarily make a view template from the correct view, and then apply that view template to the incorrect view?  Same results?
    If this is a custom image file for the render appearance please see the thread below:
    http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Materials-Render-and-Preview-Black/m-p/274...
    Lastly, if the new view specifically also appears incorrect [or any material after a change] there may be some material library or temporary file corruption.  Please reference the thread below:
    http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Revit-doesnt-render-when-I-change-a-simple...
    Please let us know once you have an update.
    Thank you,
    Ryan Duell
    Revit Clinic
    @revitclinic
