• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    aalonsojaver
    SOLID MASS, SOLID ELEMENT WITH MATERIAL
    179 Views, 3 Replies
    08-31-2012 02:41 PM
    I need to add a kind of layer to my  roof to represent an "empastado", and element that we add to the constructions in México, the way I created this element is using  a Mass.
    I want to make the mass solid to add it a material, but i cant, because the mass is divide it in faces, exists something in revit thats create like a solid element with the form that i want?
    Please use plain text.
    Product Support
    alan.quinn
    Re: SOLID MASS, SOLID ELEMENT WITH MATERIAL
    09-04-2012 09:22 AM in reply to: aalonsojaver
    I'm not sure on the material you want to add but in any event all you can really do is add the layer to the roof family, or create a roof type that only contains the layer and create that on top of another roof. Go here for information on Roof Properties: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0...
    Thanks for posting and I hope this helps.
    Alan Quinn
    Support Specialist
    Product Support
    aalonsojaver
    09-05-2012 01:19 PM in reply to: aalonsojaver
    Thank you for your answer
    I dont know if that going to result with a Roof, beacuse I need to unit de point 1 with the point 2 (image), when I modify the subelements of the roof or floor, the thickness dont change, only the slope.
    Product Support
    alan.quinn
    09-06-2012 02:53 PM in reply to: aalonsojaver
    I'm still not clear on your questing and your last image is not helpful. If you create a floor or roof by MASS you should be able to set up the thickness first, then apply it. Updating after by changing the properties will allow you to change the thickness.
    Thanks for posting.
    Alan Quinn
    Support Specialist
    Product Support
