• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Valued Contributor
    kwihae
    Room tags
    340 Views, 1 Replies
    12-22-2011 06:15 AM
    How do you make a room tag that references the following?
    Structural floor level
    Finish floor level
    Finish ceiling level
    Structural celing level
    Please use plain text.
    Employee
    loboarch
    Re: Room tags
    12-22-2011 08:29 AM in reply to: kwihae
    Room objects are not "aware" of the information you are wanting to tag.  The only way to get this information to display in a room tag would be to create a shared parameter that is arrached to the rooms in the project and then create a tag to read the shared parameter.
    The one problem with this would be the fact the information reported in the tag will not be filled out automatically.  it will have to be coordinated and updated manually.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
