• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Active Contributor
    Accepted Solution
    Room Tag Issues
    253 Views, 4 Replies
    09-18-2012 07:18 AM
    Hi
    I'm having issues with positioning room tags.
    When I try to position my prefered tag in some, mostly, small rooms I get an out of room error.
    I assume this relates to an insertion point over which I have no apparent control which can be clearly seen, a green line, when trying to move the tag - see attached screen grab.
    As I don't want to use a leader any suggestions or am I missing something obvious?
    Regards
    Christopher Alan Pitt
    Frank Shaw Associates
    Please use plain text.
    *Expert Elite*
    Re: Room Tag Issues
    09-18-2012 07:41 AM in reply to: chris.pitt
    It appears that the Elements in the Family are not located on the origin point (intersection of the reference planes). You can open the Family for editing to correct this, but all of your existing Tags will be changed as well.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Active Contributor
    Re: Room Tag Issues
    09-18-2012 08:41 AM in reply to: CADastrophe
    Noted but the family editor doesn't give me the option for reference planes, only reference lines
    Regards
    *Expert Elite*
    Re: Room Tag Issues
    09-18-2012 08:54 AM in reply to: chris.pitt
    The Reference Planes are already there. Most likely, Annotation Categories are turned off under Visibility/Graphics Overrides.
    Active Contributor
    Re: Room Tag Issues
    09-19-2012 12:33 AM in reply to: CADastrophe
    Thank you!
