• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Accepted Solution
    Rooflights in a Curved Roof
    338 Views, 7 Replies
    11-09-2012 12:30 AM
    Just wondering how i would go about inserting rooflights in this curved roof.
    Any help would be appreciated.
    Thanks.
    Please use plain text.
    Re: Rooflights in a Curved Roof
    11-09-2012 04:07 AM in reply to: paul53_7
    1st question I have is how did you create it?
    Mike
    Michael L. Maloney
    Virtual World Designs
    VDC & BIM Model Design, Clash & Coordination
    mike@VirtualWorldDesigns.com
    Building Design Suite Ultimate 2013
    Charlotte/Gastonia, NC & Jacksonville, Fl.
    Active Contributor
    11-09-2012 05:51 AM in reply to: mike
    I created the roof by extrusion and a void to cut out excess.
    *Expert Elite*
    11-09-2012 06:13 AM in reply to: paul53_7
    You can use a Window Family--Skylight, which comes OOTB (out of the box) meaning standard in the Revit Library.
    I just created a test project with a curved roof by extrusion and placed the skylights--no problem.
    see attached image.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Active Contributor
    11-09-2012 07:16 AM in reply to: ccollins
    Thanks for the quick response.
    I take it you just create vertical openings in the roof?
    How easy is it to place the rooflights in the roof.
    *Expert Elite*
    11-09-2012 07:23 AM in reply to: paul53_7
    The Skylight Window family just drops in like it would in a wall---simple as that!
    Family attached.
    Cliff B. Collins
    St. Louis, MO
    Active Contributor
    11-12-2012 01:25 AM in reply to: ccollins
    Thanks you for your help.
    Paul
    Active Contributor
    11-12-2012 03:09 AM in reply to: paul53_7
    Sorry a small problem, it is not allowing me to insert rooflights, saying it cannot cut instances.
    How do i place them.
