Autodesk Revit Architecture
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Mike Smith
Roof Framing plan - Display
Options
- Highlight
- Email to a Friend
362 Views, 8 Replies
11-16-2004 02:21 PM
Hi Everyone,
I keep getting this mixed up. I am trying to show the walls below for my
roof framing plan (similar to plan below). When I turn on my underlay
level to Fin Floor some walls do not show up nor do the window or door
openings. What am I doing wrong?
Thanks in Advance for your help.
Mike Smith
mike@mdsarchitect.com
*Paul Monsef
Re: Roof Framing plan - Display
Options
- Highlight
- Email to a Friend
11-16-2004 05:48 PM in reply to:
*Mike Smith
Hi Mike, I've attached some pics from a fairly simply house i did a short
while back in the autodesk.revit.customer-gallery newsgroup. The roof
framing plan, a floor framing plan and with the view settings i used...
Hopefully they are self explanatory.
I personally would not use the underlay option to show the walls below (but
i do use it sometimes to show the walls above), I find it prints way too
light...
For my upper roof framing plans I set the cut plane around 24" BELOW the
level. This allows me to show my bearing walls as being "cut"....
To show the Roof DARK I simply turn on the roof above as an underlay and
trace over the edges with WIDE detail lines, locking the lines to the roof
so they update...
Hopefully that helps...
Paul Monsef
TSA | architects, pllc
Production/CAD Manager
425.401.6828 x105
paulmonsef_NOSPAM_@tsaarchitects.com
"Mike Smith" wrote in message
news:419a7d6c_2@newsprd01...
> Hi Everyone,
> Mike Smith
*Jeffrey McGrew
Options
- Highlight
- Email to a Friend
11-17-2004 10:01 AM in reply to:
*Mike Smith
> so they update...
You should also look into the 'linework' tool. If you use it to make
lines bold, those lines will continue to show even when the underlay
is then turned off. So it's a more automatic way to do what you're
doing now. I use it to make, for example, a dashed line on the
floorplan for overhead elements like a skylight.
Jeffrey
*Paul Monsef
Options
- Highlight
- Email to a Friend
11-17-2004 11:16 AM in reply to:
*Mike Smith
Hi Jeffrey,
I had problems when using the linework tool on screened objects (overlay's),
even if I used the "wide" line.. For some reason it just came out "wide
screened".
I'll try it again.
Paul Monsef
425.401.6828 x105
"Jeffrey McGrew" wrote in message
news:419b91e9$1_1@newsprd01...
>> roof so they update...
> You should also look into the 'linework' tool. If you use it to make lines
> bold, those lines will continue to show even when the underlay is then
> turned off. So it's a more automatic way to do what you're doing now. I
> use it to make, for example, a dashed line on the floorplan for overhead
> Jeffrey
Options
- Highlight
- Email to a Friend
11-17-2004 01:04 PM in reply to:
*Mike Smith
Another way that doesn't seem to get much "respect" is to overlay plans on the sheet. Set up a floor plan view that shows just the elements you want to underlay in your final presented sheet. Then overlay this view on the sheet on top of the other view, they will snap into alignment over one another.
You get much better control over lineweight and you don't run the risk of undoing the linework you changed using the linework tool.
*Macdaddy
Options
- Highlight
- Email to a Friend
11-18-2004 10:43 AM in reply to:
*Mike Smith
Forgive my ignorance but this seems like such a simple task with no clear
simple solution in a program that should make it simple. Having to jump
through hoops to resolve the problem is a problem in its self. It seems
Revit has made "some" not "all" of the little easy things more difficult to
do.
Scott Robinson
Infinite Design
Architectural Design - Planning
78-134 Holua Rd.
Kailua-Kona, Hi. 96740
808-987-0193
infinitedesign@hawaii.rr.com
"Steve_Stafford" wrote in message
news:19610108.1100725525420.JavaMail.jive@jiveforu m2.autodesk.com...
another.
Options
- Highlight
- Email to a Friend
11-19-2004 12:31 AM in reply to:
*Mike Smith
What I described would take a couple minutes to do and would remain live and update automatically for the rest of the course of a project. I'm not sure how much easier it can be? In the past, I've posted examples of overlaying views on sheets in the AUGI Revit forums. Try a search for the word Overlay.
Or follow this link, you need to be a member of AUGI though (free)
http://forums.augi.com/showthread.php?t=5877
or this link
http://forums.augi.com/showthread.php?t=7570
or this link
*Macdaddy
Options
- Highlight
- Email to a Friend
11-22-2004 02:53 PM in reply to:
*Mike Smith
".....a couple of minutes...." it should take seconds. 2 - 5 mouse clicks
and your done.
news:586001.1100853140705.JavaMail.jive@jiveforum2 .autodesk.com...
sure how much easier it can be? I've posted several examples of overlaying
Options
- Highlight
- Email to a Friend
11-22-2004 03:51 PM in reply to:
*Mike Smith
All things can be improved...just offering one way to get it done now, the way things are now. I don't write the code...just use it...
If things don't make you happy, then talk with Revit Support. They'll make sure the developers know what you want improved.
