• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    Rivet License Monitor error
    93 Views, 2 Replies
    06-07-2004 11:53 AM
    Had to replace an existing Rivet license monitor with a new computer due to hard drive failure. Now, after successfully licensing the new installation, existing installed Rivet's can not license the app. Attempt to license to the new license computer returns this error message which, of course, does not appear in the knowledge base.
    "The AutoDesk Rivet License Monitor on host "57B-CC15-8515" is unable to fulfill licensing request. An error status of -12 has been returned.""
    Ideas?
    Please use plain text.
    *v.valentijn
    Re: Rivet License Monitor error
    06-08-2004 03:04 AM in reply to: rmoletti
    Make sure to have the latest FlexLM.. Check if you've given the right servername/macaddress when licensing, any mistypings? [see top of licensefile, open in wordpad].. Any network restrictions? User restrictions for any Registrykeys? You might check the error status -12 at Macrovision.com good luck "rmoletti" schreef in bericht news:16676817.1086634465969.JavaMail.jive@jiveforum2.autodesk.com... > Had to replace an existing Rivet license monitor with a new computer due to hard drive failure. Now, after successfully licensing the new installation, existing installed Rivet's can not license the app. Attempt to license to the new license computer returns this error message which, of course, does not appear in the knowledge base. > > "The AutoDesk Rivet License Monitor on host "57B-CC15-8515" is unable to fulfill licensing request. An error status of -12 has been returned."" > > Ideas?
    *Jeffrey McGrew
    06-08-2004 08:36 AM in reply to: rmoletti
    rmoletti wrote: > Had to replace an existing Rivet license monitor with a new computer due to hard drive failure. Now, after successfully licensing the new installation, existing installed Rivet's can not license the app. Attempt to license to the new license computer returns this error message which, of course, does not appear in the knowledge base. > > "The AutoDesk Rivet License Monitor on host "57B-CC15-8515" is unable to fulfill licensing request. An error status of -12 has been returned."" > > Ideas? Which version of Revit is this? And is it Revit, or Revit series? -- Jeffrey McGrew Application Specialist BSD AEC Technologies, a division of ID8 Media Inc. (415) 593-6000 x 129 (415) 593-3333 Fax (415) 505-4689 Cell www.aectech.com www.id8media.com
