• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    CavCORP
    Revit won't open after install....also cant uninstall it....
    803 Views, 4 Replies
    06-14-2011 09:20 PM
    hi guys
    im having a bit of trouple at the moment. i have just built a new desktop setup using windows 7 64bit and the last thing i had to do was to install revit 2012. once installed i tried to open it but it only opened the opening screen and wouldnt load any further then would say it wasnt responding. after a number of times restarting my computer and running windows updates etc it still wouldnt open (autocad opens fine) i decided to uninstall it then reinstall but once i select uninstall/change it does nothing....so frustrating help me please
    Please use plain text.
    LisaDrago
    Re: Revit won't open after install....also cant uninstall it....
    06-15-2011 05:26 AM in reply to: CavCORP
    I would suggest going through a clean uninstall of the revit product. I have attached a link for your reference.
    LD
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16828836&linkID=9243099
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    Employee
    06-15-2011 05:29 AM in reply to: CavCORP
    Also I would verify the following post as well:
    Revit 2012 Hangs at Splash Screen or Crashes with Unrecoverable Error
    Thanks again,
    Ryan Duell
    Revit Clinic
    @revitclinic
    Active Member
    Thiefsie
    09-18-2012 08:16 PM in reply to: ryan.duell
    Hi There,
    I've tried all the above solutions - complete uninstall - regedit removal and full reinstallation, xml file deletion etc, and still can not start revit 2012. What the hell is going on??
    Interestingly I can't install the extensions as they supposedly are installed already and I don't know the reg product ID for them so I can't manually clean them out to be installed again either.
    Can someone please help me as this is on my work computer and I can't get any work done in 2012 which is a disaster!
    All that happens when I boot Revit 2012 is a completely blank dialogue box with an OK button, and the bug report says I am getting an Unhandled Exception.
    Active Member
    Thiefsie
    09-18-2012 08:54 PM in reply to: Thiefsie
    Also installed a fresh Revit 2013 version (not on this computer before) and the exact same thing happens.... anybody have any smart ideas?
    Is it a licensing issue? I'm using the serials on the back of the boxes I have...!
