• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    Revit raw information location or "Back end Database"
    98 Views, 1 Replies
    10-09-2012 09:01 AM
    I would like to find a file which contains all the information in a project. I'm not sure what this is called...? Back end database? Raw information location?
    I would like to use this file in order to retrieve information that is lost when converting from .rvt to IFC.
    (hopefully this is  an easy question for an experienced Revit user...)
    Please use plain text.
    Alfredo_Medina
    Re: Revit raw information location or "Back end Database"
    10-09-2012 09:11 AM in reply to: g.charalambous
    Do a search about Revit DB Link. That is probably what you need. It creates a database file that can be opened in Microsoft Access. The database includes related tables, with all the information about the elements of the project.
    Planta1 Revit Online Consulting | info@planta1.com
