• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Revit.exe-No Disk
    501 Views, 5 Replies
    10-30-2012 11:47 AM
    Running Revit Architecture 2012 - Student Version 64bit
    Was running fine for some a few semesters, Then started to get this message and the Revit file would lock-Up
    Revit.exe-No Disk
    There is no Disk in the Drive. Please insert disk into drive\Device\Hard Disk\DR1
    I have updated two of the Autodesk Revit Updates, Updated Windows, Ran a Anti-Virus.
    It was working OK for a bit then again with the MESSAGE. I am not networking, or File sharing.
    I did read a message that was posted last year, followed their direction and comments still locking up.
    I did CADD Link files to REVIT, As this might have been an issue for the person posting last year.
    Any direction on how to resolve this issue would be greatly appreciated
    GR
    Please use plain text.
    Member
    Re: Revit.exe-No Disk
    11-05-2012 10:26 AM in reply to: gr8210774
    TTT
    Member
    11-06-2012 10:17 AM in reply to: gr8210774
    Product Support
    Chris.Aquino
    11-06-2012 01:09 PM in reply to: gr8210774
    It would appear your Windows setup probably registered a removable device as drive D at some stage (DR1 = drive C) and then later couldn't find it when it started up.
    If you have not already, I would try the steps on the following page:
    "There Is No Disk in the Drive. Please Insert a Disk into Drive \Device\harddisk\Dr1" Error Message ...
    Chris Aquino
    Revit Support Specialist
    Autodesk, Inc.
    The Revit Clinic
    @Revitclinic
    Member
    11-06-2012 01:20 PM in reply to: gr8210774
    *Expert Elite*
    TravisNave
    Yes, this is almost certainly an issue with a removeable device.  You're going to have to put in the removable device and then change the drive letter.  It's the only way that I know of to fix this problem in Windows.
    • Log on to the computer as Administrator.
    • Insert a disk in the removable drive.
    • Click Start, right-click My Computer, and then click Manage.
    • Click Disk Management.
    • Right-click the partition, logical drive, or volume that you want to change, and then click Change Drive Letter and Paths.
    • Click the removable drive, click it, click Change, click the drive letter that you want to use, and then click OK.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
