• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    Accepted Solution
    Revit crashes when I draw a line
    345 Views, 4 Replies
    04-16-2012 06:34 AM
    I am a high school drafting teacher and have Revit 2012 installed on the student computers. The computers are only a year old.  However, they do have integrated video.  The computers are capable of running Inventor 2012 with not problems at all.  The problem that I have having is that when I try to draw a wall on Revit, a message pops up that says "An error has occurred while drawing the contents of this window. This window shall be closed."  It only happens when I draw a wall in LINE form.  If I use the rectangle tool to draw all 4 walls at the same time, it doesnt crash.  HELP!
    Please use plain text.
    Employee
    loboarch
    Re: Revit crashes when I draw a line
    04-16-2012 01:09 PM in reply to: ecrompton
    This message typically happens when there is a problem with the graphics card/driver on the PC.  You can try turning off hardwarfe acceleration in the Options menu (found on the big purple "R").  This may help with the situation.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    Member
    04-17-2012 04:06 PM in reply to: loboarch
    Hello, I'm a new user. I've got the same message when I draw a wall. I tried  turning off hardwarfe acceleration in the Options menu but Revit still crashes on me.
    Salem
    Salem B. Abdalla
    Architecture Engineering Department
    College of Engineering
    Sharjah University
    Sharjah, PO Box 27272, UAE
    Tel: +971-6-5050814
    e-mail: sabdalla@sharjah.ac.ae
    New Member
    10-02-2012 12:14 PM in reply to: ecrompton
    It happened to me too.
    I did turn off the graphic acclleration om the Option Menu at the upperleft R icon.
    I reloaded, repaired and reinstalled to no avail.
    Please help, we are having a class here with 2 students and the instructor seems to be in desperate mode.
    New Member
    10-02-2012 01:21 PM in reply to: qtarchitect
    It works now, I follow Jeff Hansen's post:
    just remember to x out the program and reopen it for the change to be affective.
    Thank you Jeff.
