• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Mentor
    Revit Server question?
    319 Views, 3 Replies
    10-11-2011 11:55 AM
    When sending consultants models we typically sent the file located right on our server.  With  Revit Server users can't get to the Revit Server as a drive letter map (that I am aware of).  How would we continue to send Central models to our consultants?
    Thanks for the help.
    Please use plain text.
    Re: Revit Server question?
    10-11-2011 01:42 PM in reply to: Caddman13
    You need to Save -as and Detach from Central, and rmove any Linked files.
    Then post the Revit model(s) to the FTP site. ( and have the engineers do the same when posting. )
    cheers
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Active Member
    11-14-2011 12:21 PM in reply to: ccollins
    We've been successfully using the Revit Server Command-Line Utility to cut a local file, and use that to send. This way, if you have multiple models, it can run unattended. It still takes time to convert the server-based worksharing files to a single RVT, but is mush less stressful.
    Active Member
    11-14-2011 12:22 PM in reply to: sburke
