• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    Revit Server problems with large files
    1680 Views, 24 Replies
    01-31-2011 08:16 AM
    We have setup server between offices and it works great for small files, but when I am trying to save large files I get the error "The Revit server you are trying to access is not
    available due to a server or network failure. If you
    have models from the Revit server open, save any
    changes locally and contact your administrator.
    Also if we try to lock the folder it says cannot lock folders.
    not sure what the couse of this is.
    Please use plain text.
    Employee
    Re: Revit Server problems with large files
    02-01-2011 01:24 PM in reply to: nmysorewala
    Do you know if you have any bandwidth or file size restrictions?  I know it is technically possible to restrict packet size or prioritize which packets get priority over the network [such as Outlook traffic, Revit traffic, etc] but you should verify this with your IT department if possible.
    I would verify the steps in the post below to see if everything else appears normal:
    http://revitclinic.typepad.com/my_weblog/2011/01/10-revit-server-troubleshooting-next-steps.html
    Thank you,
    Ryan Duell
    Revit Clinic
    @revitclinic
    12-07-2011 02:53 PM in reply to: nmysorewala
    I am having a similiar problem.  Here is what I can do:
    1) I am able to download a large file as a local file from a remote central server, but I get two error dialogue boxes in the process ("This operatoin could not be completed because of a problem in the Revit server network.  Please try again.")
    2) I am able to create a new central file on a central server if the file is small (I know 60+MB files aren't working, but haven't actually tested where the limit is).
    3) I am able to modify a downloaded local file, and save the file back to the central server (I can then redownload the file from the central server and see my chages, but I get the same erros again (see item 1 above).
    I am at a loss.  I have checked permissions and they all seem ok.  w3wp.exe is running with username "Network Service".  I checked the permissions of that username as well and it seems full control as well.
    Again, I am able to save small files, just not big files, and I don't understand why I would get the error dialogue boxes...
    Please help!
    12-09-2011 08:23 AM in reply to: nmysorewala
    Perhaps it is a RAM / memory problem with the physical server(s) ? Check the specs on them.
    I'm assuming they are all WinServ 2008 R2 64 bit.
    Latency/bandwidth could also create a bottleneck which won't allow the Synch to execute.
    How is your WAN configured? Firewalls and VPN tunnels? MPLS?
    cheers
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Active Member
    lksvdd
    01-25-2012 02:28 AM in reply to: nmysorewala
    The last post in this threat is quit old, that's suggests that al the problems with big files and Revit Server are solved.
    BUT...
    We, a middle size architecture company in the Netherlands, still have this problem, we are running the latest versions ofRevit sever, including the latest service pack and an bug fix.
    We have an "Revit Local Server (RLS)" AND a "Revit Central Server (RCS)" within our own LAN, the files files of the partners are smaller, so they work fine, all our other project work fine, but our biggest Revit Project (file size approx 250MB) can't be saved to the Revit Server.
    It does not matter if I connect to RLS or directly to RCS, both in our own LAN.
    WHO KNOWS A SOLUTION TO THIS PROBLEM?
    Thanks in advance..!!
    Chris hanschen
    Cad Manager at LKSVDD architecten BV, Hengelo, the Netherlands
    01-25-2012 11:35 AM in reply to: nmysorewala
    Try using CMD ipconfig /flushdns and renew to refresh the adapter settings.
    The error message from your 1st post indicates a network connection problem; I doubt if the file size is the issue?
    But, just to be sure:
    how much RAM do you have on the workstations and server(s)?
    cheers
    Cliff B. Collins
    St. Louis, MO
    Active Member
    lksvdd
    01-25-2012 11:27 PM in reply to: ccollins
    yesterday, we have upgraded our server from 4GB to 8GB and from 1 to 2 processors.
    We did a test and the results indicated a short of memory, but the problem still remains....
    I will try your suggestion with "/flushdns", but I don't think it will help because the a machine reboot should do the same, right?
    "I doubt if the file size is the issue?" -> all our smaller projects work fine, even from the same workstation
    Thanks for your reply.
    Chris Hanschen
    LKSVDD architecten, Hengelo, The Netherlands
    Active Member
    lksvdd
    01-25-2012 11:48 PM in reply to: lksvdd
    I made a screendump of the message, this message appears after the progressbar get's to 100%
    I am connected directly to my Revit Central Server in our own LAN.
    PLEASE HELP ME OUT......
    Chris Hanschen
    LKSVDD architecten BV, Hengelo, The Netherlands
    Alfredo_Medina
    01-26-2012 05:14 AM in reply to: lksvdd
    Your server had 4 GB of RAM yesterday!? And you "upgraded" it to 8? and you are surprised that it still does not work?
    Just my laptop has 8 GB. Therefore a server must have at least 12, or 16, or more!. No wonder you are having problems.
    Planta1 Revit Online Consulting | info@planta1.com
    Active Member
    lksvdd
    01-26-2012 06:58 AM in reply to: Alfredo_Medina
    This is a virtual server for Revit Server only, no other programs or processes (non windows) run on this machine.
    But, you have a point, so we will try again with more GB..!!
    to be continued.....
    Chris Hanschen
    LKSVDD Architecten BV, Hengelo, The Netherlands
