• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    Re: Revit Server 2012 installation error
    12-02-2011 05:27 AM in reply to: mathijs.maertens
    I'm experiencing exactly the same error! I have been searching the net for ages but no solution yet. I also contact our Autodesk supplier, but they have given me the same "solutions" as I found on the net and Alan posted here...
    Can anyone help me with this issue, please?
    Please use plain text.
    Active Member
    mathijs.maertens
    12-07-2011 12:58 AM in reply to: fguypen
    Hello Alan, Thanks for the FTP access.  I've uploaded the contents of the %temp% folder (after the failed install)
    Active Member
    mathijs.maertens
    12-14-2011 12:56 AM in reply to: mathijs.maertens
    Alan many thanks for sticking with us and sending the information from the server lead.  As the installer ultimately failed because there was no default web site in IIS, here's how I recreated the "default web site" in IIS:
    I was able to reconstruct the "Default Web Site" by adding the following lines into the C:\Windows\System32\inetsrv\config\applicationsHost.config file. This xml file hold the configuration information for IIS 7.x management console. It was missing the information for the Default Web Site.  The code block I added back is located in the <system.applicationHost> section.
           <sites>
                <site name="Default Web site" id="1" serverAutoStart="true">
                    <application path="/">
                            <virtualDirectory path="/" physicalPath="%SystemDrive%\inetpub\wwwroot" />
                    </application>
                    <bindings>
                            <binding protocol="http" bindingInformation="*:80:" />
                    </bindings>
                </site>
                 <siteDefaults>
                    <logFile logFormat="W3C" directory="%SystemDrive%\inetpub\logs\LogFiles" />
                    <traceFailedRequestsLogging directory="%SystemDrive%\inetpub\logs\FailedReqLogFiles" />
                </siteDefaults>
                <applicationDefaults applicationPool="DefaultAppPool" />
                <virtualDirectoryDefaults allowSubDirConfig="true" />
            </sites>
       </system.applicationHost>
    Restart IIS 7 after making the change.
    New Member
    micky.wong
    03-26-2012 08:17 PM in reply to: mathijs.maertens
    I got the same problem an same error, however my problem already fixed.
    From my installation process, it will show "internal information services connection failed" which actually cause by missing IIS role services "managemnet tools". When all options under management tools are installed, installation success without and error.
