• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    mathijs.maertens
    Revit Server 2012 installation error
    884 Views, 13 Replies
    10-03-2011 07:52 AM
    when I try to install revit server 2012, I get an error "there is a problem with this windows installer package. A script required for this install to complete could not be run.  Contact your support personnel or package vendor.
    When I check the install log, it has this error:
    "InstallRevit ServerFailedInstallation aborted, Result=1603"
    This is on a server 2008 R2 and all prerequisites have been installed.  Anybody experienced this problem before?
    Please use plain text.
    Product Support
    alan.quinn
    Re: Revit Server 2012 installation error
    10-04-2011 10:11 AM in reply to: mathijs.maertens
    A few things may be causing this. See this link and pay particular attention to #1: http://revitclinic.typepad.com/my_weblog/2011/05/3-revit-server-2012-installation-tips.html. Also, if this is not the case I’d go back and check the prerequisites, .net, etc...
    Thanks for posting.
    Alan Quinn
    Support Specialist
    Product Support
    Active Member
    mathijs.maertens
    10-06-2011 01:18 AM in reply to: alan.quinn
    thanks for the reply.
    Indeed we are running the setup this way and I double checked prerequisites
    After googling, I tried solutions from the following links, but non of these files/reg keys are present
    http://upandready.typepad.com/up_and_ready/2011/08/windows-the-hklm-software-autodesk-registry-key.h...
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16828836&linkID=9243099
    I checked the anitvirus logs: nothing is being blocked.  I also tried to run the setup on a test server with an identical antivirus / group policy and there the installer runs fine so I've excluded anitvirus / group policy.
    I deleted everything in the %temp% folder
    Disabled UAC, no success either.
    Really stuck here...
    Active Member
    mathijs.maertens
    10-10-2011 11:24 PM in reply to: mathijs.maertens
    Installed 2008R2 Service pack 1 but unfortunately the installer still errors out
    Could it be a problem that LMTools is already installed/running on this server or that Revit is not installed?
    Even our vendor has run out of ideas...
    Product Support
    alan.quinn
    10-11-2011 08:18 AM in reply to: mathijs.maertens
    I asked our Revit Server lead to take a look at this one. I will update when I hear back from him.
    Alan Quinn
    Support Specialist
    Product Support
    Active Member
    mathijs.maertens
    10-14-2011 04:17 AM in reply to: alan.quinn
    looking forward to the feedback, thanks
    Active Member
    mathijs.maertens
    11-02-2011 07:32 AM in reply to: mathijs.maertens
    hello Alan, any news from the revit server lead?
    Product Support
    alan.quinn
    11-03-2011 08:54 AM in reply to: mathijs.maertens
    Sorry for the delay in getting back to you. We have a meeting this afternoon and I will be brining up this case. I'll let you know what I find out.
    Thank you,
    Alan Quinn
    Support Specialist
    Product Support
    Product Support
    alan.quinn
    11-10-2011 01:19 PM in reply to: alan.quinn
    Try the following:
    [1] Clear out %temp%
    [2] Run the RS install again
    If you still have issue
    [3] Collect everything in %temp% and send to ADSK for further analysis. (We'll figure out how to do this later)
    Thank you,
    Alan Quinn
    Support Specialist
    Product Support
    Active Member
    mathijs.maertens
    11-15-2011 07:59 AM in reply to: alan.quinn
    ok I tried deleting everything in the %temp% folder once more, however the error remains.
    Where shall I send the zip file?
