• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Distinguished Contributor
    Revit Sections
    180 Views, 1 Replies
    12-11-2012 01:41 PM
    Revit sections....
    I am used to Autocad Architecture where I typically detail out my sections.  I show the top and bottom plates, gypsum wallboard, beam sections, ACT tile layout, etc...
    In Revit, the annotation scale seems to be too small to make it look good.  I just get thick lines at 1/4" scale - looks sloppy.  I have detail set to fine, but it does not seem to do anything until I set the scale to 1-1/2"=1'-0" or greater.
    Just curious how everyone else does it.  Are your sections just basic linework and you dont add components until you get into wall sections or details.
    I have watched tons of videos, and read the tutorials but I have not yet seen anyone actually take a section from start to finish on the sheet.  Everyone just shows how you put the section mark down and it atuomatically creates a section view....  Thats great but there is a lot more to do in my mind, I think I know how to add the callouts and annotation but it does not seem very good if I am not pointing at the insulation or pointing to the beam, etc...
    I hope this makes sense - any help would be appreciated!
    Steve Miles
    Please use plain text.
    *Expert Elite*
    Re: Revit Sections
    12-11-2012 01:58 PM in reply to: SMILES
    check this website out:
    http://revit-detail.blogspot.com/
    As for your question--Revit uses WYSIWYG ( what you see is what you get )--so, the "thick" lines you see when zoomed in are how they will plot/print. You can use Thin Lines view setting to see more fine detail when editing; but it will not print as displayed in Thin Lines view.
    Just like text sizes and annotations adjust per view scale and plot accordingly.
    Revit differs from Cad here--no more annotation plot scales ( 1/96 xp, blah blah....)
    Do not add Detail Components at scales where they will not read or print properly--add them into enlarged details
    with scale greater than 1/2" as a rule; or even larger--1", 1 1/2", 3", 6" etc.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
