• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Active Member
    MS_jkimc65
    Revit Parameters
    216 Views, 1 Replies
    11-13-2012 10:18 AM
    Has anyone set up a Room Tag to include occupant load factor and # of Occupants, I have a fair idea in creating the labels bu unsucessful in getting it to work since I am trying to use the Area parameter in conjunction with the OLF parameter to get a calculated value to the # of Occupants?  Any ideas is greatly appreciated.
    KIm
    j. kim candelario
    method-studio, inc.
    Please use plain text.
    Active Contributor
    Re: Revit Parameters
    11-13-2012 05:43 PM in reply to: MS_jkimc65
    The OLF in a tag is fairly straightforward.  It just needs to be a Shared parameter, most likely a "number" format.  It's the number of occupants that will be elusive as Revit doesn't allow a Calculated value to be part of a tag.  I can send you the sample file that I've used in this video if you'd like.
    http://www.youtube.com/watch?v=R50XzC3ghO4&feature=share&list=PL19262EC9FFAC7422
    Glynnis Patterson, Architect
    www.ideatebimlink.comwww.ideateexplorer.com
