• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Revit LT 2013 & Residential Framing
    362 Views, 4 Replies
    12-10-2012 08:46 AM
    Has anyone completed a residential roof framing plan with Revit LT? If so, will you please share with me how you did it.
    Please use plain text.
    Active Contributor
    Re: Revit LT 2013 & Residential Framing
    12-11-2012 02:29 PM in reply to: bcarriere
    OK, Anyone using Revit know how to do residential framing (floor & roof framing) in Revit LT?
    Please note in Revit LT there is no "beam system" icon/option.
    Employee
    loboarch
    12-12-2012 10:30 AM in reply to: bcarriere
    You can place individual instances of a beam (or other framing member) and then use the array command.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    Active Contributor
    12-12-2012 05:28 PM in reply to: loboarch
    Jeff,
    Thanks for the reply! So, in this case, using Revit LT is no different than using AutoCAD (copy and/or array) with the exception that when the beams are arrayed they show up in all applicable views?
    Valued Contributor
    12-12-2012 08:57 PM in reply to: bcarriere
    Yes plus they are 3D. Move it in any view it changes in every instance. You can move the arrayed set or individually.
