Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Revit Export DWF Origin & Coordinate System
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm exporting a Revit file to DWF for coordination purposes within BIM360 Glue.
The DWF format doesn't export the Shared Coordinates, but the Project Origin as 0,0,0. In there a way I can manually indicate whether the exported file will use the internal coordinates of the Revit project, or coordinates that are shared with other linked models (simialr to DWG/DXF units and coordiantes export options)?
This is incredibly frustrating when merging several AutoCAD based DWG files or Navisworks NWC files (with same insertion point) and one architectural DWF that appears roatated 90 degrees in the federated coordination model.
Re: Revit Export DWF Origin & Coordinate System
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Kindly review this other thread:
As far as exporting thr shared coordinates to DWF please see below:
From the following thread:
http://forums.autodesk.com/t5/Autodesk-Revit-Archi
Currenlty, there is no shared coordinate setting when exporting DWF.
I would encourage you to log enchancement request with the link below, our product design team will read all the submitted forms. Select the Autodesk Navisworks for the product field.
http://usa.autodesk.com/adsk/servlet/index?siteID=
Hope that helps.
Fernanda Lima Firman
Revit Support Specialist
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
