• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    Revit Daylight Saving Accuracy
    169 Views, 2 Replies
    01-24-2013 09:25 AM
    A question regarding to the accuracy of "daylight saving" tool in Revit has araised in my office?  The time zone for Toronto is set to -5:00 eastern time during NON daylight saving hours, and during the daylight saving hours, which is from March to November, the time will get push forward by 1 hour.  We have notice with the daylight saving on, the shadows for March to November are accuracy.  However when it comes to December to Feburary, the shadows are off by 1 hour.  I wonder does that mean when doing the shadow study for December to Feburary we need to remove the "daylight saving" setting from Revit.  Can anyone comments on this?
    Please use plain text.
    Alfredo_Medina
    Re: Revit Daylight Saving Accuracy
    01-25-2013 01:30 PM in reply to: jacksonfung3916
    Recycling part of my comments to a previous discussion about this topic in another forum (up to Revit 2012) : "The check mark for Daylight Savings does what it is supposed to do only in part. Because it does not verify if the current date is out of the summertime in a particular location. It just moves the shadows one hour. ... So, use that setting with caution."
    (I wonder if something has changed about this after Revit 2012).
    Planta1 Revit Online Consulting | info@planta1.com
    Active Member
    01-25-2013 01:33 PM in reply to: jacksonfung3916
    Thank you for your confirmation.  As far as I know there are no changes made to the daylight saving tool in Revit 2013.
