• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Revit Configuration File
    295 Views, 2 Replies
    01-15-2004 11:52 AM
    Greetings,
    Just got Revit 5.1L (havent rolled out 6 yet). Ideally, I would like to configure 1 PC to use certain options (drive mappings to support files, etc). Is there a config file for revit that if I copy it to other PC's the mappings to the libraries on the network will be already mapped?
    Thanks!
    Please use plain text.
    *Greg Cashen
    Re: Revit Configuration File
    01-15-2004 12:01 PM in reply to: jwolfer
    look at the revit.ini file in the program directory "jwolfer" wrote in message news:32344393.1074196462929.JavaMail.jive@jiveforum2.autodesk.com... > Greetings, > > Just got Revit 5.1L (havent rolled out 6 yet). Ideally, I would like to configure 1 PC to use certain options (drive mappings to support files, etc). Is there a config file for revit that if I copy it to other PC's the mappings to the libraries on the network will be already mapped? > > Thanks!
    Distinguished Contributor
    01-21-2004 08:57 AM in reply to: jwolfer
    REVIT.INI file
