• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    jorgedelacova7458
    Revit Architecture 2013 - Interoperability Enhancements
    199 Views, 2 Replies
    07-16-2012 12:36 PM
    Is there a general consensus regarding the interoperability enhancements in Revit Architecture 2013?  How well does it integrate MicroStation?  Are there any settings that make this integration work better?
    Please use plain text.
    Valued Contributor
    Re: Revit Architecture 2013 - Interoperability Enhancements
    07-16-2012 01:38 PM in reply to: jorgedelacova7458
    The only improvement that I know of is now when you import
    dwg lines, Revit won't tell you most of those lines are useless
    and off axis. Because now Revit will move those line into a
    precise Revit position automatically. But I haven't found that
    to be worth much. And I don't find the notion of "interoperability"
    to be worth much either. You look at drawings from some
    other program and you start a Revit project from them. If there
    are dimensions on those other drawings, then you can start
    your Revit model that much quicker.
    Product Support
    fernanda.firman
    07-31-2012 09:59 AM in reply to: jorgedelacova7458
    All new enhancements for 2013 can be found in this page:
    http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0001-What%E2%80%99s_N1/0002-New_in_...
    Fernanda Lima Firman
    Revit Support Specialist
    Autodesk, Inc.
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
