Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Revit Architectu re 2012-2013 edit boundary ribbon issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We fixed it by starting a session of Revit double clicking the file in it's folder vs. opening the file from within Revit.
We do a bit of programming here with Addins and we think the addin has caused the issue. The addin won't load if you start Revit by doublle clicking the filename.
Mark.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
One of our clients found that rolling back to an older .NET installation fixed the issue which was happening in 2012 and 2013.
Re: Revit Architectu re 2012 edit boundary ribbon issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Opening the Revit file with a dobbleclick does the trick for me... Strange! Maybe someone from Autodesk would like to comment the subject?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I came through the same problem after installing the Microsoft .NET Framework 4.5 with Visual Studio 2012. After removing it and reinstaling the previous version of the .NET framework (Version 4), everything went fine.
www.bim42.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is finally a fix for the issue.
Hotfix - Autodesk Revit 2012 - Ribbon behavior due to .Net 4.5 installation
Mark.
