• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Re: Revit Architecture 2012-2013 edit boundary ribbon issue
    10-10-2012 01:56 PM in reply to: regalith
    We fixed it by starting a session of Revit double clicking the file in it's folder vs. opening the file from within Revit.
    We do a bit of programming here with Addins and we think the addin has caused the issue. The addin won't load if you start Revit by doublle clicking the filename.
    Mark.
    Please use plain text.
    Member
    edwin
    10-11-2012 10:49 AM in reply to: mark
    One of our clients found that rolling back to an older .NET installation fixed the issue  which was happening in 2012 and 2013.
    New Member
    Re: Revit Architecture 2012 edit boundary ribbon issue
    11-13-2012 01:26 PM in reply to: archytextural
    Opening the Revit file with a dobbleclick does the trick for me... Strange! Maybe someone from Autodesk would like to comment the subject?
    New Member
    Jesuite
    02-01-2013 01:13 AM in reply to: edwin
    I came through the same problem after installing the Microsoft .NET Framework 4.5 with Visual Studio 2012. After removing it and reinstaling the previous version of the .NET framework (Version 4), everything went fine.
    Simon Moreau
    www.bim42.com
    Member
    03-18-2013 02:15 PM in reply to: mark
    There is finally a fix for the issue.
    Hotfix - Autodesk Revit 2012 - Ribbon behavior due to .Net 4.5 installation
    Mark.
