• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    Revit Architecture 2012 - Error Message
    242 Views, 2 Replies
    09-10-2012 10:46 AM
       My computer crashed and now I cannot get on any of my autodesk programs.  I am in need of the programs to finish all my homework due next week.  Revit comes into a view mode and says: 4)autodesk revit architecture 2012 build 20110309_2315(x64)   License unavailable.  A license is required to run autodesk architecture 2012 on this computer.  How do I fix this problem.  Autodesk Revit architecture is in viewer mode.
    Help!!!
    Please use plain text.
    Re: Revit Architecture 2012 - Error Message
    09-12-2012 10:10 AM in reply to: driskilltr
    not sure about this,but can you borrow a license?
    TravisNave
    10-03-2012 11:02 AM in reply to: driskilltr
    You will need to reactivate your product.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
