• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Revit 8.1 Network Installer Problem
    36 Views, 3 Replies
    08-23-2005 06:11 AM
    Greetings,
    I am rolling Revit 8.1 out to a few users via a network install.
    The problem I am facing is that after the installation (done under administrator profile on Windows XP Pro PC's), when the user logs on, they do NOT see the start menu shortcuts for 8.1
    Turns out that 2 problems seem to be creeping up.
    1. The security permissions on the Docs and Settings/Autodesk/Autodesk Revit Building Systems 8.1 folder are for admin only, so I need to manually add access for the domain users.
    2. On a couple PC's the short cuts have actually be placed in the Admin Start Menu folder, rather than All Users.
    What is going on with this?
    Please use plain text.
    Member
    Re: Revit 8.1 Network Installer Problem
    10-28-2005 12:46 PM in reply to: jwolfer
    I have the same problem. I am re-creating the deployment with the . (period) removed from the file paths, as in "Revit Building 8.1" Maybe that's where the installer fails?
    I am surprised that there are not more complaints about this issue.
    If anyone can shed any light on this, it would be appreciated. Is Autodesk listening? If so, maybe they have some suggestions?
    Bruce
    10-28-2005 12:49 PM in reply to: jwolfer
    Just to update you. I still do not have a fix for this. I have tried to recreate the installer and whatnot, to no avail.
    If you find a fix.. please let me know :smileyhappy:
    Member
    10-28-2005 12:58 PM in reply to: jwolfer
    Changing the install path did nothing.
    I didn't find anything useful in the Network group, either.
    This is very frustrating.
