- Mute
- Permalink
- Report
I have the full Revit (inc. MEP, structural and arch) and since there isn't a "Revit" section, I thought posting here.
Everything works fine, I can open the previously opened projects or the sample projects (the ones that show up on the screen). I also can open up families. BUT when I try to open a project by either clcikcing "OPEN" (see attached screenshot) or via the file menu, Revit crashes (not responding...) when it is supposed to bring up the folders to search for files.
The only way to workaround is to go to the "R" and "open" "any Revit file". I googled for it and didn't see anyone else having the problem.
I assume it is an IT problem here because: my old PC (only had 4 GB) had the same problem and I thought it was because of lack of memory. and at home on my PC I installed Revit to try this problem, it works. (and no, our IT is not helpful with things like that). but now I have a 24 GB PC with 3.6 GHz quadcore... so power shouldn't be the problem. but i have the standalone license and the project being on the network isn't the problem since it crashes already before picking a project, and with my workaround it works.
Any idea what could cause this and how to resolve? Apparently i can open my projects with the workaround, or once they show up in the selection of previous projects. Really where it hangs is whne it supposedly opens the folder structure to pick a project. i can open families without problem. (it is not one of those file format problems with 203/2012 files etc.)
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
