Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Revit 2013 and Globe Link
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I was just wondering if anybody has managed to get the Globe link extension to work with 2013. I keep getting the error
"You must turn off Google Earths Terrain before acquirment"
I get this even after turning off the terrain feature.
I have installed the latest version of Google Earth.
Re: Revit 2013 and Globe Link
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What version of Global link are you using?
Google link was optimized for the Google Earth version 5.0, so this could be a possible reason why acquire doesn't work.
It also could be your regional settings of your Windows (decimal symbol = point, digital grouping symbol = comma)
As far as this issue is concerned, could you fix the problem by changing this setting or using GE version 5 (or combining both)?
Our developers are aware of this issue and working on a fix.
Fernanda Lima Firman
Revit Support Specialist
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm using the latest version of Google Earth Pro v 6.2.2.6613 (April 11 build) and found the only way yo get revit 2013 to view in the latest version, is to export as kmz after adjusting the project location, then importing the kmz to GE. Its a bit tricky on location to get the insertion point correct and not all shapes came in, I could import simple mass and construction shapes, fence, but not all families import. Has anyone else experienced this? As for windows comma and decimal, I di check and the setting were correct, I wondered, thiugh if Windows need a 7 decimal place setting versus 2 as that seams to be how accurate GE is for lat/long (see attached)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not to be a pest, but are you working on it? I have been trying to use this tool for a couple years now and have never once seen it work properly. I mean how long does it take to fix it? This would actually be a really handy tool if anyone could get it to work.
