• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Revit 2013 and Citrix
    569 Views, 7 Replies
    11-12-2012 02:35 PM
    Revit 2012 and Citrix Xenapp work great. We upgraded to 2013 and now everything as slowed down so much it is basically not useable. Has anyone else delt with this issue? Is it a by product of Revit 2013, are their some graphic issues present in this release currently not in 2012? Anyone else experiencing this issue?
    Please use plain text.
    Product Support
    Re: Revit 2013 and Citrix
    12-26-2012 01:57 PM in reply to: jimk
    Dear jimk
    The issue you are describing has been reported to development group and is currently under investigation.
    Best regards
    John Lipp
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    01-28-2013 07:32 AM in reply to: john.lipp
    Any new info on this issue?
    Active Contributor
    02-05-2013 07:07 AM in reply to: mlestes1
    I wish there was. The problem is still a glaring issue with no solution. I am fairly certain there won't be. I am hopeful that 2014 will run better, but we could be faced with the same problem in that release as well. We are looking at trying to accelerate the data with Cisco WAAS as it will work with citrix. Hopefully can get equipment in place in a few weeks and test. 2012 still runs excellent, and we try to keep as many projects in that version as we can.
    Member
    04-11-2013 02:43 PM in reply to: jimk
    I'm seeing similar problems.  Was there ever an update on it?
    Active Contributor
    04-11-2013 03:01 PM in reply to: stip1
    No I never received a solution for this. I am hoping 2014 is better, I see the did some video stuff in that release. What is so disappointing is 2012 works and runs like a champ.
    Active Contributor
    05-07-2013 08:37 AM in reply to: john.lipp
    2014 is showing the same behavior as 2013. How could this not be addressed, is there anything we can do? Why say it works on Citrix when you can't hardly run it on Xenapp
    Member
    M.Abrahams
    05-12-2013 10:24 PM in reply to: jimk
    Attn: Autodesk Urgent!
    This is a serious issue that could have major ramifications to the operations of some companies. 2012 had been working fine on XenApp but 2013 was just far too slow. My understanding from the documents I had read from Autodesk, was that Revit was supported for citrix for 2014 but by the sounds of it, that isn't the case. We are about to test it ourselves but this could have a serious impact on our systems and projects.
    Having this fixed for 2014 would be great but we will still have a large number of projects in 2013 that would be affected if/when crossed over to XenApp so a fix for 2013 would also be needed.
    Please give us some form of indication whether this will be addressed and addressed soon.
    Cheers
