• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    srobinson
    Accepted Solution
    Revit 2013 - Work Flow for Materials
    1897 Views, 5 Replies
    05-04-2012 03:30 PM
    For a number of years, I have been "making do" with the OOTB materials supplied with Revit.  I am now ready to start creating my own materials to exert a greater level of control on how my projects appear in shaded and rendered views.  Autodesk seemingly has outdone themselves in making this a complicated and opaque process...and help does not really provide much help.  Revit behaves very oddly/illogically once I try to step out of the basic steps in WikiHelp.
    I am focusing on the appearance and graphics assets of materials, how to create my own libraries, how to use the asset editor, etc....all with an intent to getting beyond what simply ships with the software.
    My question is this...I can't find anything that really shows the work flow for making custom material libraries and the logic behind them.  There is lots of information on clicking buttons and selecting things, but once beyond that, help doesn't really help.  Can anyone direct me to a resource that maps the workflow, logic and interrelationships between Material Browser, Material Editor and Asset Browser/Editor?
    Please use plain text.
    Valued Mentor
    vector2
    Re: Revit 2013 - Work Flow for Materials
    05-04-2012 04:12 PM in reply to: srobinson
    srobinson wrote:
    "I have been "making do" with the OOTB materials supplied with Revit.  I am now ready to start creating my own materials"
    "There is lots of information on clicking buttons and selecting things, but once beyond that, help doesn't really help"
    Okay great, you just need theory and logic.
    Here's some theory about creating custom materials.
    If you find the most amazing rock wall in your town
    and you would like to have that on your Revit models,
    do this:
    1. Get a digial camera with a really good lens.
    2. Put the camera on a tripod at a far distance
    from the wall, like across the street. (You don't
    want the wide-angle view, you want the flat view.)
    3. Download the image from your camera to your
    computer.
    4. Go into the materials dialog and duplicate any
    material and give it a new name for your wall.
    5. Then just do your "lots of information on clicking
    buttons and selecting things" and render your model
    with your new rock wall.
    Be a super-custom super-user.
    Valued Mentor
    vector2
    05-04-2012 10:39 PM in reply to: vector2
    I need to mention something here about materials where
    an Autodesk employee previously pointed out my failure
    to do so.
    There are many ways to configure those OOTB materials.
    Colors can often times be changed, bump maps can be
    changed etc etc. The high res OOTB images are second
    to none for quality. They are all highly useful if any of them
    are what you need.
    Member
    ryanh
    06-21-2012 08:36 AM in reply to: srobinson
    To start off i would like to say that i believe you missunderstood the question Vector.  Before 2013's rediculious addition of more "options" to the materials browser creating your own material was clean and easy.  I am having trouble understanding the structure which is used to create the new materials- to me it seems that the material editior now has a duplicate material editior within it which makes no sense at all!  we now have to name a material in the (in document materials) material list as well as create another new material within the material for its appearance.. anyone that can explain this?  would be greatly appreciated.  (i am looking for an explanation which clearly states the advantage of having materials that have materials with material properties within them)so confusing but thats how it is set-up.  I can now create a duplicate material from the main materials browser but when i go to edit this material to give it its own properties it changes the properties of the material i duplicated... why??
    Valued Mentor
    vector2
    06-21-2012 08:55 AM in reply to: ryanh
    ryanh wrote:
    I believe you missunderstood the question Vector.
    I did read the question again and it still looks to me like they wanted
    to know how to make their own materials as opposed to using OOTB.
    They did mention that they thought the new materials UI was complicated,
    but nothing like your long rant about it.
    The last time anything changed with Revit rendering and materials was
    with the 2009 release, it's still the same.
    08-31-2012 01:07 PM in reply to: srobinson
    Hi srobinson. The same happened to me when duplicating a material, I don't understand either why the original material changes. But I found out a workaround. Please check this comment I posted in the wikihelp and you might also find useful the response I got from Kevin Dolley.
    http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/3032-Customiz3032/3042-Project_3042...
