• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    kwihae
    Revit 2013 Stairs by Compoenent depth clipping in plan
    185 Views, 3 Replies
    12-17-2012 06:27 AM
    I have a fire escape stairs running from the basement to the 4th floor on the exterior of the building.  This is built as one element.
    Does anyone know if there is a way to clip the view of this stair so that only a portion of the stair is showing?
    For example, I would only like to clip out the stairs in the basement in the 4th floor plan.
    Please use plain text.
    Re: Revit 2013 Stairs by Compoenent depth clipping in plan
    12-17-2012 08:38 AM in reply to: kwihae
    You could try using a Plan Region, and set the View Range specifically for your pruposes at the fire escape.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Valued Contributor
    kwihae
    12-17-2012 09:56 AM in reply to: ccollins
    Tried it, but didn't work...
    12-17-2012 12:27 PM in reply to: kwihae
    Can you post an image or a stripped down version of the revit file?
    Cliff B. Collins
    St. Louis, MO
