• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    Revit 2013: Shifting Properties and Project Browsers
    505 Views, 4 Replies
    08-25-2012 08:52 AM
    When I open a new drawing, or when I shift between a .rfa and .rvt file, the Properties and Project Browsers of each that were situated on the second monitor revert back to the first monitor where the drawings are.
    What an annonyance!
    (There are not other Revit users with two monitors that have complained about this before for Autodesk to have addressed this issue already?)
    TO Autodesk:  Please explain why this continuous inconvenience has not been resolved yet. i.e.,., why the dialogs do not stay in the user's preferred place when a second monitor is used?
    Is there still not a way that these can be easily locked in place?
    Please use plain text.
    Product Support
    fernanda.firman
    Re: Revit 2013: Shifting Properties and Project Browsers
    09-05-2012 05:59 PM in reply to: octavio2
    Kindly refer to this post:
    http://forums.autodesk.com/t5/Autodesk-Revit-MEP/Locking-project-browser-amp-properties-dialog-boxes...
    Did that help?
    Fernanda Lima Firman
    Revit Support Specialist
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
    Member
    09-28-2012 10:36 AM in reply to: octavio2
    WTF?  Why refer someone to a thread that has no solution?
    I have this same issue, why doesn't autodesk allow Revit to save it's workspace in the same manner autocad does?
    I've read that the issue may be related to specific video card drivers, but the simple solution is to allow workspaces to be saved...
    Member
    10-11-2012 11:39 AM in reply to: m.haney
    i run a duel moniter set up and the properties and project browser over lay on the second monitar i want them to be side by side.. this is only an issue in 2013
    New Member
    04-10-2013 10:32 AM in reply to: octavio2
    I have the same problem - no solution since 2012??
