• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Re: Revit 2013 Rendering Issue: blue and yellow pixels
    07-23-2012 10:47 AM in reply to: villarrealmon
    Some materials have a very shiny or glossy property--such as steel with a polished finish, or a highly reflective glass.
    Try building a quick "test" project, and use only some very simple, "matte" finish materials, and then do a rendering at the same settings as your project with the yellow/blue pixels.
    The test project should render correctly. If it has the yellow/blue problem, it could be something with your display driver/video card/hardwar, etc.
    Then look at your main project and try to identify the materials which may be causing the problem. Water, Glass, Metals come to mind.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Please use plain text.
    Active Member
    07-23-2012 10:56 AM in reply to: ccollins
    I changed the finish of the materials I used from Glossy to Matte and did a test draft rendering and it came out ok. I'm currently rendering at high quality but I think that was it!
    Thank you so much for your help!
    Valued Contributor
    07-23-2012 12:01 PM in reply to: villarrealmon
    Let's see it.
    Active Member
    07-23-2012 12:18 PM in reply to: vector3
    It didn't turn out as OK as I thought it would. :smileysad:
    It's set on medium quality with the sun from top left
    Valued Contributor
    07-23-2012 12:35 PM in reply to: villarrealmon
    Good enough to sell the concept.
