• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *Harlan Brumm \(Autodesk\)
    Revit 2011 hangs when opening or creating a new project
    2093 Views, 9 Replies
    04-22-2010 10:38 AM
    Hi All,
    Wanted to let you know about something that has
    just come up in Product Support.  Revit 2011 products appear to hang if the
    ArchVision Content Manager is set to local with no executable location.
    You can start Revit, but not open or create a project.
    We've created a Technical solution that explains
    how to fix the issue:
    Hope this helps,
    Harlan Brumm
    Autodesk Product
    Support
    Click Here to Take Our Survey: http://www.surveymonkey.com/s/86MH8JX
    Check
    out Autodesk Blogs: http://blogs.autodesk.com
    Please use plain text.
    Re: Revit 2011 hangs when opening or creating a new project
    04-24-2010 05:19 AM in reply to: *Harlan Brumm \(Autodesk\)
    Hi {font:Arial}{size:2}Harlan {size}{font}
    This has not fixed my hang issue. I am running Revit 2010 and 2011 (64bit) on a Dell M6400 notebook quad core system with Windows 7 64 Ultimate, 8G RAM. The time to start a Revit session from scratch is currently 4 minutes?? on a system that has been starting Revit 2010 in under 15 seconds.
    The initial install worked fine last week but on Friday, the start-up times across the system starting slowing. The existing Revit 2010 version completely stopped and would not start. Revit 2010 had been running well for the last year. The AutoCAD 2010 also slowed taking nearly two minutes to start-up.
    So far, I have removed the entire 2010 and 2011 Revit suites along with the 2011 Max Design and reinstalled only Revit 2011, remove the virus software, cleanly uninstalled Revit 2011 following your sequences below, reinstalled the video drivers and still no joy.
    Seems to hang on the "recent files screen" and I do remember there was an issue with this screen and its compatibly with IE 8? with Revit 2010 64bit.
    Any ideas apart from completely rebuilding my system from scratch. All the other software loaded on the system is working fine.
    The Hang Description is as follows:
    A problem caused this program to stop interacting with Windows.
    Problem signature:
    Problem Event Name: AppHangB1
    Application Name: Revit.exe
    Application Version: 2011.0.2010.326
    Application Timestamp: 4bad4bff
    Hang Signature: 2087
    Hang Type: 256
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 5129
    Additional Hang Signature 1: 2087cbf4f22d616f1e2511d3de6aea29
    Additional Hang Signature 2: 1033
    Additional Hang Signature 3: 103340becbdf202639dbb844fceb771c
    Additional Hang Signature 4: 2087
    Additional Hang Signature 5: 2087cbf4f22d616f1e2511d3de6aea29
    Additional Hang Signature 6: 1033
    Additional Hang Signature 7: 103340becbdf202639dbb844fceb771c
    I will also log this as a case though my subscription site.
    Kerry
    04-26-2010 03:36 PM in reply to: *Harlan Brumm \(Autodesk\)
    Hi
    Thank you for every ones input.
    In the end I rebuilt the system re-installing Windows 7 64 and I must say it was a lot less painful than I thought. Whole process, including reinstall of software takes around 4 hours.
    In relation to the problems above, I was also having issues with 2010 so made the decision to replace the operating system. The installed Windows 7 was an upgrade on Vista 64 so there was probably a few issues lingering from that.
    Windows 7 64 reinstalled itself while keeping all my data, copying the program specific data into a windows.old directory and after installing the Dell system drivers etc., my Revit 2011 now loads in 15 seconds rather than 10 minutes. 2010 works as well.
    I made sure I could see the "hidden files" in the Windows Explorer in order to access the Program data directories.
    All in all it solved the issue and is probably the way to go if the effort involved in solving an issue is more than 4 hours.
    Did have a slight scare when installing a program called AutoIT which I use for CAD and BIM automation. Installing this software with its 64bit extensions compromised the operation of Revit so it was backed out and installed as a 32bit application.
    Kerry
    Edited by: ktaltd on Apr 28, 2010 12:59 AM
    New Member
    05-22-2010 05:10 PM in reply to: *Harlan Brumm \(Autodesk\)
    Hello Kerry,
    I am having the same issue with Revit 2010. Unfortunately, nothing changed on my computer. I bet you something was changed online at Autodesk however that is causing all of the Revit 2010 versions to now have a hickup.
    That is unfortunate since I am trying to participate in that student competition and cannot get Revit 2010 to work.
    I cannot reinstall my OS (I also have a fresh install of Windows 7, so no, not a chance that this is an upgrade issue). I used to work in computers and I bet this is some registry key that changed.
    I have not had any luck reinstalling Revit 2010 and will now give up in frustration. But Autodesk seriously needs to accept responsibility for this. Every time the version changes the older ones stop working. I have bought my computer mainly to run Revit 2010 and sorry, it is simply unacceptable that this software is suddenly no longer running.
    Did they reply for a solution to you otherwise?
    Thank you
    Sylvia
    Active Contributor
    06-09-2010 06:23 AM in reply to: *Harlan Brumm \(Autodesk\)
    The link to the techincal solution link does not work. When you scroll over it is not a clickable link. I have seen this issue throughout other Autodesk pages. Please fix this.
    Product Support
    06-09-2010 08:36 AM in reply to: swebster
    I've updated the thread so that the link should be working now.
    Harlan Brumm
    Product Support Technical Lead - Revit Architecture
    Global Subscription and Support
    Autodesk, Inc.
    Valued Contributor
    09-22-2010 04:44 PM in reply to: *Harlan Brumm \(Autodesk\)
    This fix only works if you don't have too much content in your RPC folder.  I made the fix, but Revit kept hanging as soon as I tried opening a new or existing project.  After doing a little digging on the internet, I discovered that if you point ACM to a folder with only a few RCPs than Revit opened as it should.
    Does Autodesk have a fix for this yet?  Right now I have to point to the folder with fewer RPC to get Revit to launch, but change it to the full folder if I want it all to show up in Max.  Its an ok workaround, but certainly not ideal.
    I'm only mildly interested in RPC content in Revit, but I really need it in Max.  Is there any way to disable the whole RCP search within Revit, so I get the full benefit in Max and can still open my revit without changing paths in ACM?
    Product Support
    09-23-2010 07:28 AM in reply to: sgoodmansen
    Unfortunately, there is not a way to disable the whole RPC from running.  Right now, the only workaround is changing the folder to one that has less RPCs as you said.  I beleive that the number of RPCs that Revit will not hang with is about 300.
    The good news is that this is currently planned to be addressed in the next update for Revit 2011 products.  I cannot say when the updated is going to be released, and sometimes, things that are planned to be fixed miss the cut, but right now, it is planned to get fixed.
    Harlan Brumm
    Autodesk, Inc.
    Valued Contributor
    09-23-2010 08:05 AM in reply to: harlan.brumm
    Thanks Harlan, good to know you guys are working on a fix.
    New Member
    bxi1
    09-09-2012 02:20 AM in reply to: *Harlan Brumm \(Autodesk\)
    I'm running revit architecture 2011 on parallel desktop 7, Intel quad core GHz, 16GB Ram 750 HDD Ati radon 6570M. i com across the exact same thing, revit just hang there with a spining circle of the curser.  I try to open revit.ini but i can not locate the [ACMsetting] . However revit 2011 will run on a 4GB ram, Intel core i3 1.33gHz, 320GB HDD with imbuilt graphics hard.  I don't see why it's doing this.  System requirements shouldn't be the problem.
    Description:
    Problem signature:
    Application Version: 2011.0.2010.903
    Application Timestamp: 4c81b6b1
    Hang Signature: 6f7f
    Hang Type: 256
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 1033
    Additional Hang Signature 1: 6f7fdbe11f5cbc55870291980279f715
    Additional Hang Signature 2: d9f3
    Additional Hang Signature 3: d9f3f36fb405da507fbe20ffc3386ffa
    Additional Hang Signature 4: 6f7f
    Additional Hang Signature 5: 6f7fdbe11f5cbc55870291980279f715
    Additional Hang Signature 6: d9f3
    Additional Hang Signature 7: d9f3f36fb405da507fbe20ffc3386ffa
