Revit 2011 Rendering Issue
My Specs: Revit 2011 (update 2) Windows 7 64bit, 24gb ram
Issue: When i draw an object and then render it, no problem. When i try to edit the material, then render it again however, the object does not render at all. It is not even visible. Every time i try to edit the material, something seems to happen.
I open Revit 2010 models and wait for the upgrade process. Then when i render, only the RPC objects appear.
The same object is visible in realistic view with the correct material displayed. HELP!
Note: I used revit 2011 on my old computer (Vista 32bit, 4gb ram) and there was no problems. AUTODESK, WHAT IS GOING ON?
ryan.duell
Can you verify if the following process resolves the issue?  It sounds like the same issue:
http://revitclinic.typepad.com/my_weblog/2011/02/troubleshooting-elements-that-disappear-when-render...
Thank you,
Ryan Duell
step 1 resolved my issue.
