Autodesk Revit Architecture
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Revit 2011 - 100'-0" Datum Elevation
- Highlight
- Email to a Friend
In Revit 2011, I'm trying to change the first floor level from 0'-0" to 100'-0" (datum). I have tried Manage-->Project Location -->Position-->Relocate Project, but nothing happens and there are no error messages. Thank you in advance.
Re: Revit 2011 - 100'-0" Datum Elevation
- Highlight
- Email to a Friend
After you have done your listed steps and adjusted your project "up" 100', you need to do one more thing.
Highlight one of the Level lines in an elevation or section view. In the Properties box, pick Edit Type. In the Type Properties dialog box, change the Elevation Base parameter from Project to Shared.
Your Level elevations should now show the new elevations.
www.dougbowersconsulting.com
blog: http://aectechtalk.wordpress.com
(Previously posting as Doug Bowers through Newsreader for several years)
- Highlight
- Email to a Friend
Worked like a charm. Thank you Douglas.
- Highlight
- Email to a Friend
No problem. I'm glad that worked for you.
- Highlight
- Email to a Friend
I'm using Revit 2013, I've done all the same things. But when I select the Level Line, then Edit Type, Type Properties, the only options under Elevation Base are Project Base Point and Survey Point. Is there a different way to change the 0' Elevation Base in Revit 2013?
- Highlight
- Email to a Friend
Here is an articel in the wikihelp covering this topic.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
- Highlight
- Email to a Friend
The 2013 solution works just great
