• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Rendering problem
    173 Views, 6 Replies
    01-18-2013 05:49 PM
    Hello, Im haiving problems witn my rendering,  yesturday everithing was working fine but today everytimie i set rendering quality higher than draft, Revit either fails to render (rendering area goes black) or the pc crashes and i get bluescreen.
    Please use plain text.
    DarrenP
    Re: Rendering problem
    01-18-2013 06:01 PM in reply to: poxil
    probably not a revit issue
    thats a hardware problem most likely
    your probably overheating the computer
    Member
    01-19-2013 02:11 AM in reply to: DarrenP
    I dont think so, as i said everything was warking fine. It goes to 10% of render in less than 10 seconds then it thinks a bit  and it goes to 100% full complete render which is black...
    My pc is intel i7 3.5ghz, 8gb ram and gefoce gtx680. I checked out the temperatures during the process and its slightly above 60.
    I got message from revit: Unknown error occured...
    Distinguished Contributor
    jz4all
    01-22-2013 03:44 AM in reply to: poxil
    Hi
    I experienced  such a thing time ago. But after restarting my computer twice, everything turned back fine.
    Verify your graphics card, maybe it is not good enough for such mission!!!
    DarrenP
    01-22-2013 06:03 AM in reply to: jz4all
    have you looked up the blue screen error
    that will tell what the problem is
    its not going to be revit
    DarrenP
    01-22-2013 06:54 AM in reply to: DarrenP
    Member
    01-22-2013 12:16 PM in reply to: DarrenP
    It is not happening in other projects, only in this one, blue screens are not showing up anymore, it just doesnt render.
