Autodesk Revit Architecture
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Renaming exisiting parameters - Assembly Code
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
273 Views, 3 Replies
12-22-2011 02:18 AM
Is there a way to rename the Identity Data Parameter- Assembly Code?
Re: Renaming exisiting parameters - Assembly Code
Options
- Highlight
- Email to a Friend
12-22-2011 03:01 AM in reply to:
kwihae
No. Some parameters are kind of hard coded into the families, and cannot be changed.
Planta1 Revit Online Consulting | info@planta1.com
Options
- Highlight
- Email to a Friend
12-27-2011 06:41 AM in reply to:
kwihae
just make your own shared parameter and use that instead. My is called AssblyCode
Dave - DDP
Acad 2012 and Revit 2012
Win 7 Pro 64 bit
Intel I7-860 @2.8GHz
12GB DDR3 RAM
GeForce GTX260
Win 7 Pro 64 bit
12GB DDR3 RAM
GeForce GTX260
Options
- Highlight
- Email to a Friend
05-09-2013 07:51 AM in reply to:
WorkerBeeatDDP
you can.
follow instructions as per the link below (basically editing a .txt file (uniformatClassifications.txt file)
worked for me. i had concrete piles with the assembly description as steel pipes (for some reason)
i closed my revit sessionI, went into the aformentioned .txt file and changed it to concrete.
apologies if i'm talking out of my left ear and misinterpreted what you mean.
Pete
