• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    References not found in Arrayed Items within a Family
    172 Views, 5 Replies
    08-14-2012 01:28 PM
    With some help obtained in another thread, I'm pretty close to finishing a family for an exterior trellis element (attached).  The problem now is that the arrayed support pieces cannot be dimensioned to their centerlines except for the first two items in the array - the items used to establish the array.  Any support pieces beyond that can only be dimensioned to their faces - Revit sees no centerline.  Is this a "feature" of arrays or have I constructed the family incorrectly?
    Please use plain text.
    Re: References not found in Arrayed Items within a Family
    08-14-2012 01:40 PM in reply to: paul.ashley
    Try including a Reference Line (not Plane) in the arrayed Group.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Valued Mentor
    08-14-2012 01:48 PM in reply to: paul.ashley
    Add a line or Reference Line to the Array by editing the group and adding an object.
    This will give you a snap point for the dimensions.
    08-14-2012 02:02 PM in reply to: CADastrophe
    I tried a model line and that worked but the reference line idea is better since it isn't seen.  I added it to the family of the item to be dimensioned but I may try adding it to the array itself to see if there's a difference in how the tow solutions work.
    It still seems odd, though, that the references are lost beyond the initial elements of the array.  Thanks for the help.
    Valued Mentor
    08-14-2012 02:12 PM in reply to: paul.ashley
    I use Invisible symbolic lines also to do that same thing.
    08-14-2012 02:28 PM in reply to: Caddman13
    Thanks for all the help.  It's working fine now and I've learned something new.
